Lumia 820 broken screen, which parts though do I need to buy to repair it?
  • Start date
Lumia 820 broken screen, which parts though...
So my lumia 820 fell quite hard today, screen got cracked quite badly, but i can see the display properly, and a quarter of the screen is reacting to touch input, so i'm trying to figure out which parts i should get to repair it and/or where is the best place to get them,
Thanks
Harrie-S
Retired Ambassador
Sep 26, 2014
5,378
Re: Lumia 820 broken screen, which parts though...
The touch screen is damage so that's the part you have to replace.
Because you still see pictures (over the total screen) means your LCD is still okay.
The touch panel is a glass plate with touch layer and part of this touch layer is not cracked so it still is useable.
So you need to get a touch panel but you also can buy a touch panel a front housing
like this.
Nokia Lumia 820 Digitizer Touch Panel Screen - ETrade Supply
Or a touch panel only like
Nokia Lumia 820 Touch Screen|Digitizer Panel - ETrade Supply
The one with front housing is easier to replace but check some youtube video's how to do it.
Now I do not know if above supplier is reliable but the links are for reference.
DrPendragon
