Battery charger
Yes but don't expect it to be quick. You have less than 1A charging there. It's going to take some time to get to 100%.
Any reason why you want to use this charger? Looks old.
I you do not mind a long charging time yes.
The output is 5 Volt and 650mA.
The 1520 charger is I think normally 5 Volt and 1300 or 1500 mA so your charger is good but will be slow.
ok so I picked up a 1.5 amp charger. My phone was ay 9 percent with the 1.5 charger it took 4 hours to reach 100 percent is that normal?
dannakari
