Battery Drain - Charging and battery doing down?
dkp23
1,494
Just installed 8.1. Had some account syncing issues getting stuck. Did a airplane mode, reset, delete, and add back accounts and it seems to work. It isn't stuck on syncing anymore.
So through all this, i have my phone on tryign to play around with settings and put it on charge at 76%. Went to the bathroom and came back, now at 74%? on charge and the phone doing nothing.
The phone is quite warm though as well.
Anybody else havign this issue?
I find after applying updates that the percentage shown for the battery is inaccurate. It takes another charging cycle before it starts working properly.
I had this so I turned it off and on and plugged it into a wall socket. Was previously in the USB charger.
cyberxpert
