Battery drain when charging
Arlan Henry
133
Nokia Lumia 1520 running 14342.1003 with a two month old new, official replacement battery.
If my battery drains below 60%, then it will continue to drain even while charging. The only remedy for this is to put the device into airplane mode.
feedback-hub:?contextid=404&feedbackid=e8b938eb-12a4-483e-9dbf-eab6ad4e7c1b&form=2&src=2
Did you check what was hogging the battery in settings? .1004 is now available, which you probably know about, and there have been fixes for battery issues.
Well done for keeping the fab 1520 up and running. Those devices will attain mythical status before long!
I didn't check but .1004 seems to have sorted the issue. Ran an Apo called Rescue Tests and checked the battery, status: Good.
Sdiolutola
