Battery fix in 8.1?
SoullessOnyx
378
Hey...
So I have owned 2 Nokia Lumia 920's and both have had a terrible battery life... Like, it is just so bad an Nokia should feel ashamed of the creation that is the Nokia Lumia 920's battery life.
I am not saying the 920 is a bad phone because it is not! It is fantastic, the only thing that stops it from being perfect is the battery life.
Please don't say you must just have battery drain... No, everyone I know that owns a 920 has the same problem.
Anyway, do you think Windows Phone 8.1 will change anything about the 920's battery life? Make it better or worse?
I'm not sure if the battery life will be better or worse, but there will be a Battery Sense application included in 8.1, which will be able to pinpoint apps that are draining battery life. Think data sense, except for battery usage instead of network usage.
i have a 920 aswell and found that changing my screen brightness to low on automatic setting has made a difference and also check whats running in your background tasks here drive+is a huge battery drain when not being used.it works for me
Latest posts
leo0000157
