battery issue in latest redstone 14393.67 mobile build
parasharkunal001
I've updated my phone to new redstone build 14393.67 and I'm facing fast battry drain issue l. I've tried resetting my device twice but its of no use . My battry gives backup of 2-3 hrs only and also getting hot like coals whike charging. Is this an bug in the latest build or there is something wrong with my device coz before update i was not facing any of these issue. So please help me ASAP
THANKS IN ADVANCE 🙂
THANKS IN ADVANCE 
As always said, especially on odelr phones: device needs a couple of days, first for updating all core apps, then sync and caching. Let it plugged and wifi connected.
Resetting too close make worst, because phone must restart by zero donwloading, sync and caching.
Consider your phone like a little notebook.
My 735 runs well, same like pre-RS when using, better battery life when not in use. Update everything, after a few days see if it helps.
Try opening all the open all the apps and then turn off unneeded background apps, such as Photos, WhatsApp, Block and Filter(If you're using Truecaller) etc.
I have L 730 and after updating to 10.0.14393.189, the battery life is miserable. Did two hard reset without any improvement. The phone is heating up while doing simple internet surfing on home Wi-fi. Charging the battery even with original charger (a new original charger bought few months ago) showing slow charging message. The battery is not charging or even the percentage is decreasing while simultaneously charging and actively using the phone. On top of it, the phone is not detected by my laptop by connecting via USB cable (showing device descriptor request failed; error 43).
Is NFC turned off?
chrishorner68
