Battery Plugged in - not charging.
vEEP pEEP
1,264
Hello,
My battery is close to dead. I plugged it in via USB to my computer. I know it will be slow but in 3 hours it shows a 2% increase using the built in Battery Saver.
The battery indicator indicates it's charging (flashing plug), but batter says it is plugged in, but not charging.
So what is going on?
I did a hard reset on my phone last month.
Reboot daily.
Thanks,
Mr. V
USB to Computer charging is always going to be significantly slower than a direct plug in to a wall. Unplug it and re-plug it in, your charging stats should update.
Android_Creator
