Building a computer.. Need help.
You can use a mouse/kb with the Xbox 360? o.0
Can you play games with the mouse? This just might get me to finally buy an Xbox if it's true.
you can use the keyboard through the usb on any xbox.
There are however a few accessories you can buy to connect between the mouse and keyboard to the xbox that will translate your keyboard and mouse movements into xbox controller movements! One for instance XCM
Here is some good advise for ya.
If you need to ask a bunch of strangers on a message board for advise you shouldn't be building your own machine. Go pickup something off the shelf with a decent vid card. Ideally on sale. Throw some more RAM into it and your done.
You gotta start somewhere! That's how I started learning and I've built about 5 machines while still in high school! Probably put together about $12000 worth of computer!
Building a PC on your own is a cool experience, it really teaches you a lot! I suggest anybody with a passion for tech build their own computer! Its cheaper in the long run because its easy to upgrade so it will never become dated!
MamasKoekeloere
