Headset + Power Adapter/Splitter for BJ II
GregJDT
Love the new BJ II, came from the Treo 700w. So far, digging it way more. The only thing that concerns me is that there is one data/headset port on the device. I like to use wired headsets as I never remember to charge the BT headset, but I can't use a wired headset and charge the BJ in the car at the same time. Does anyone know of a "splitter" or adapter which would give me two plugs for the BJ II? Thanks in advance.
tsk... I don't think there is. I *would* suggest you use go Bluetooth and then use a USB cable and a mini-hub to power off a carcharger->usb adapter, but as I just posted in this forum that doesn't seem to work.
Which basically sucks if you're using the thing for GPS in the car. I just asked our store's guy who knows every smartphone product on the planet and he says the thing doesn't exist at all (but that he'd carry it if it did). :(
aardales
