Help!!! Phone showing as highest drain in battery saver, even when no calls are made all day
irvin792
1,152
Sorry of this is posted somewhere else, I know the forums are full of battery problem threads but I'm curious about others with this exact problem with the Phone showing as the highest drain with nothing else even coming close even though the phone has maybe made 1 call all day and was using IE11 and texting much much more
This is regarding my wife's 920
How is your coverage in the area where you are? If signal is poor, and your device is searching for a signal, that will cause battery drain. If you have WiFi, anything that uses data will not show battery drain, but the phone will, since voice does not use IP at this time. Once LTE-Advanced is available, and phone calls are done via data, not voice, then there won't be any differences; however, at this point, voice uses mobile network, not WiFi, which would drain battery in areas where signal strength is low.
Signal is very good at home and work, before 8.1 was installed battery would last much longer. I have scoured the various threads and tried all the tips and fixes people suggest......i am at a total loss, my wife's 920 is dying in 5 hours.........where as my 1520 is running great, same if not better than 8.0
LTE however is not yet available at my home or our work area but AT&T "4G" is strong
I have a 920, and I haven't noticed any differences in battery life between 8.0 and 8.1. I've never used battery saver.
4 email accounts all set to manually sync
Internet sharing off
Lock screen timeout 1 min
Wi-Fi on
Bluetooth off
NFC off
Battery saver off (read that it may be a culprit)
Brightness automatic
Backup all off
Find my phone only second box checked
Sync my settings all off
Quiet hours off
Location on
Advertising ID on
Feedback enabled
Sunlight readability on
Touch sensitivity normal
Double tap to wake on
Glance off
Apps running in background : Cortana, Battery Saver, Internet Explorer, Facebook, Calendar, Here Drive+, Weather, OneDrive, Live Tile countdown, Chase Mobile, Skype
(7 above apps are not OS apps)
She never ever plays games
Sorry for the long post, trying to be thorough
ikemefuna1
