Help! Problems with updates and Nokia Mix Radio +
rohan tewari 007
Hi there from India
I just bought a Lumia 720 from UAE and i've been countering some problems
First of all the phone updated to Amber but did not update to Black
Second,I've got the code for nokia mixradio but when i put it in the activation box it says activation failed, and when i contacted the Nokia care they said that they could not do anything bout' it
because of some issue with the IMEI No., Also i had a Mix radio subcription in my previous Lumia 620 which i lost, and i log in with the same ID in Lumia 720
Third, the store is not getting any of the app updates
PLeasseee help me PLease
Hi there from India
IMEI problems/ Maaan, can you try to flash the Indian Rom onto the phone? Search the forums for a relevant thread.
Signout from the Nokia Mixradio and sign in with a new userid. input the code then. That should work theoretically.
Goodluck
Goodluck
I'll try the first option but yeah i tried signing out and then signing in, even uninstalled it but it logs in with the same id
