[HELP]Severe Battery Problem
akulgupta100
41
Since the past 2 days I'm having severe battery issues...
Charging takes all eternity and it is all drained in 5hours max.
I'm so fed up of this
I tried
>Soft reset
>Full discharge and charge again
Also
Phone becomes a furnace while charging
NFC and GPS are off
Any suggestions?
Also a reboot causes drastic battery level changes
Before reboot battery was 50% and 99% after reboot
And while charging , i have observed the charging led alternatively flashing red and green
Thanks in Advance
Sent from my Windows Phone 8X by HTC using Tapatalk
Reset to factory defaults and see if the battery still drains. Then you know if it is hardware or software. Make sure you have backup on first
