How can i teach cortana where is my work place and my home?
levalencia
17
After doing that, how can I tell cortana to open a map app to go home/work?
thank you!
thank you!
Open Cortana from the pinned tile or directly from the app list. Tap the icon on the very top right (three lines). Now tap places and the + button in the bottom app bar. Look up the address you want to add and tap the entry that's displayed. You can now choose to make this your home, work or "other" address. You can additionally add a nickname which - according to the description - makes it easier for you to find your places, should you happen to have a lot.
Not sure if you can make Cortana open the map with one of your predefined locations by just using your voice. I've never tried that myself, tbh.
dksdjkdjkdsjkds
