How do I quit apps corner without using power button?
Status
Not open for further replies.
vrkratheesh
How to quit apps corner without using power button?
Hii I am using Lumia 620. My lock button is broken. I am using touch lock app to lock and double tap to unlock it. Unfortunately i launched the apps corner. Now i don't know how to get out of it? pls help me
Re: How to quit apps corner without using power button?
Maybe you can do a battery pull to restart the phone?
I'm not sure if it will do that, but I hope it will take you out of it.
If the battery pull doesn't work, with the back cover off try pressing the exposed power switch with a toothpick or paper clip. If the switch doesn't operate it may have broken free from the solder. You can try pressing the housing together where the switch is and try again. Here's a link for a possible DIY switch repair that looks fairly simple if you want to give it a shot: Lumia Side Button Not Working Fix No Need To Disassemble 520 620 Others | TopicNow.info
Status
abcdzoony
