How much extra battery is double tap to wake using on your phone?
mogelijk
123
I've noticed that double tap to wake appears to drain my battery faster -- I've not done a real test but, from my limited watching it, it seems to take my battery life down 2-4% per hour instead of 1-2% when my phone is idle. Just curious if anyone has tested this and if others are seeing that it is basically doubling the battery use when the phone is idle?
honestly should never turn it on for a lumia 920 .. I ran through pretty quick and had to charge my phone twice in 8 hrs. Didn't check the %, but turned the double tap of it has been a bit better. But I think the :CD screen on 920 is bound to lose charge coz of glance.
Marchwind1949
