ok i have a surface i got off ebay for 200....the only problem with it is that the lcd ribbon cable hasa short in it. Anybody know where to get a replacement from?
If anybody reads this I found a compatible cable for the lcd flex cable! It was a tight fit and it's a little long but It's working fine with my surface pro.
I don't have enough posts to link but if you go to mouser.com and look up the part "15015-0451" you should see it.
