Ok. So I've had this 820 for the past 8 months. But then recently (2 days ago) the battery went nuts. I'm losing 2% every 5 minutes, opposed to 2% every hour.
I'm on amber.
The things that have happened in between my phone being normal and it going nuts were:
Facebook Beta was updated (uninstalled)
Hardware Tests was updated (uninstalled)
Sys app Pusher was updated
The three above probably didn't cause it
Next two:
My plan was cancelled: I'm a bit behind on payments on it... So could it be randomly trying to search for signal?
I removed my micro sd card and put it into my computer to view the files inside before returning it into my phone... (I did all this before turning on the phone again. However, I did not safely eject the sd card from the phone so there may have been some problems?)
Whatever the issue, my phone has not been hot such as times when gaming. However, it has always been slightly warmer to the touch than before it had this issue. The heat issue is fixed when I go into airplane mode.
Any help is appreciated. Thank you.
I'm on amber.
Next two:
