My MicroSD detecting a problem everytime I switch on my L520.
Frankwess12
17
I accidentally pulled out the battery from the phone hence a forced switch off. I know this might have caused it but how do I solve the SD problem without losing my data?
gpobernardo
Jan 12, 2013
4,339
When it comes to SD Card problems, the safest recommendation would be to copy all your data from your card to your PC or phone (as a backup) and then purchase a new SD Card.
The other recommendation would be to use your PC to try to fix any errors your SD Card has. This works at times, but most of the time when an SD Card has started to fail or has been damaged it becomes write-protected and unfixable.
Frankwess12
17
Oh...thats scary. Thankyou. Getting to the back up right away then.
mayamirza33
