Need Help... Call & SMS filter wont work..
NightOrchid
242
Hi All
Ive had to install my System apps, such as Audio, Glance Screen, Network+.. and so on through Sysapp Pusher because for some reason when I do a factory reset under Cyan it removes them, which is not an issue... as long as they work.
One of the Apps I especially want is Call&Sms Filter as Iam getting spammed by cold calling and canvassing and recorded advertising.. sometimes as much as 3x a day at one point, but for some reason Filter wont work when I install it, even when I reboot my phone.. it says
"Cant open filter at the moment. Please try again Later or restart your phone"
Which ive done. I know im not the only one as many have had this issue but have solved it by a restart or rebooting the phone first then starting the app.. still wont work.
See the problem I have is that I have my own independent Alternative therapies business and i use this phone, which i answer automatically as it could be a client.. which isnt so bad if theres a live person on the other end because they just hang up as we all know cold canvassers can be charged for wasting a companies time and money.. but its the damn answering machine messages.
I do intend to call up O2-UK on monday because under EE and Virgin.. this spamming was never this bad and its driving me nuts.
So can you guys please help me get this working.
This has worked for me before. But now, and with the latest DP, no longer works. I have uninstalled, setting the date to 11-11-2114, open, it will tell you to uninstall... and put the date back. Installed it again... no luck, same error message.
What to do?
I have Lumia 830 with the DP activated. This is the Denim update and windows version is 8.10.14192.280.
niedrie
