nokia lumia 720 battery life max 1 day with battery saver :/ is this normal ?
I have the same problem with my battery before. 100% charged but only has a battery life of 22 hrs. I tried a hard reset and it was fixed. Before this occurred, I had Asphalt 8 installed (which was a battery hog) so I didn't install it after the hard reset. Make sure to backup your data. And there's no need to format the SD card if you plan on hard resetting it, btw.
Works fine now; I get 2 days 8 hrs at most with everything turned off (except flight mode) and roughly 1.5-2 days on moderate to heavy usage. Wish I could get 3 days on this one but I get I'm just too greedy lol.
Hard reset really works! Before hard reset my phone was discharging at 3.8% per hour. Immediately I start browsing it could shoot you 4.2%. But after I did hated reset the maximum discharge is 2.8% per hour. Thanks alot for the tip guys
Nated2
