please help--battery issues on 1520
adijosh2011
23
I degraded my Lumia 1520 from 8.1 to 8.0 because of heating and battery drain by Nokia software recovery tool.
Even after degrading to windows 8 battery drain problem still exists.(no more battery heat).
what shall I do is my warrenty void ? Shall I give the phone in Nokia care??
ven07
6,892
If you downgraded to 8.0 you can bring the phone in :) Your warranty is not voided because they can't prove that you had 8.1 :) you should remove the dev preview app tho.. However if the phone is fairly new then battery drain is to be expected :)
revanthpallagani
48
If there is no heat then chances are it is because of battery calibration. Use it for a couple of weeks, make sure you always charge to 100% before plugging out.
You can even try the 'drain out completely and charge to 100' method. That definitely helped me.
adijosh2011
23
update:
battery life has improved because of unknown reasons..2days passed n it still is 45%
revanthpallagani
48
That's good news.. A new phone or a new OS will need some time to understand your battery capacity based on your usage. I don't know about 1520's battery but 45% after 2 days sounds very good.
Windows user fan
