Powerbutton issues, unlock problems, long loading times, can't find WiFi, higher drain of battery
klose91
23
Hi there, since three days I have some weird problems with my Windows Phone. I'm running the latest DP on an 8s. So, the problem is, if I'm pressing the power button to unlock the phone it takes a long time and the screen is black for that long time. It happens also that after unlocking it, that it can't find my WiFi Network anymore, only after restarting the phone it finds it again. And I've noticed problems with my battery. It drains faster than before and gets also very hot. Apps also began to take more time to load or to response, and it gets much more worse if I'm charging my phone. Does anyone knows if this is some serious bug in the DP? I want to avoid to do an reset of my phone, is there maybe a solution to these problems?
Im running into the same issue it just started this week with no changes to the profile of apps or configuration. Not sure what is going on. I holding off a reset as well. Im on att 1520 latest dp build.
Has anyone tried with a restore rather than new phone build after reset ? It's quite painful to reset and manually getting it back with apps and tiles. Many thanks in advance!
I have reset the phone, for now it seems like the problem is fixed. But I will observe if theses problems come again.
Btw, it's so good that syncing apps, settings and start screen works so great, that it's not such a pain to reset it, and mostly everything can be restored.
jakki
