Rogers Lumia 920 MMS and Tethering problem solved on T-Mobile
vs6xfx
33
After updated to 1232.5957.1308.0000
Upon restore my phone from backup, I disable to installation of ACCESS POINT and make the below change to the MMS settings. My phone recover the ability of Internet Sharing.
Therefore, I suspect that after the installation of the Access Point and make the selection in Access Point (Active), this change disable the capability of Tethering.
My settings are as below:
DO NOT install ACCESS POINT
Go to Setting > Cellular
Add internet APN
Proxy server (URL)
fast.t-mobile.com
Proxy port
80
IP type
IPv4v6
Add mms APN
WAP gateway (URL)
wap.voicestream.com
WAP gateway port
80
MMSC (URL)
http://mms.msg.eng.t-mobile.com/mms/wapenc
MMSC port
80
Max MMS size
1024
IP type
IPv4
The above work for me and hope this also help others on TMO.
Wow, this looks promising! I have an unlocked Lumia 920 originally from Rogers too. When down in the US I had a Roam Mobility SIM in and it worked, but I was re-directed to the T-Mobile to buy an Internet Sharing Plan :P Roam is a Canadian Re-seller of service for Canadians while in the US. Great concept, but there are some road blocks to get around before the Sharing will work. Roam's deal with T-Mobile was to include the Internet Sharing apparently. I was told that MMS was simply not going to be available. I will see what I can make happen with your settings, my Roam SIM and *611 support (apparently it will be T-Mobile).
Cheers,
Scott
Hey guys, any instructions for windows phone 8.1? data on phone works, but internet sharing does not.
nimblehuman
