Slight rattle on volume rocker and power button?
Alex Dean
95
Hi guys,
Just wondering if this is normal or not. I noticed it when I first opened the box but since I was so excited to get to know the phone I kinda ignored it, but my volume rocker and power button are a little loose fitting, even so much as they move a tiny bit when touched and (very faintly) rattle when I shake the phone. The camera button is unaffected though.
Just wondering if you guys have it on your models (i.e this is normal and the buttons are just a little loose fitting) or I have a problem?
Yeah, I know what you mean. I guess I could learn to live with it; I'll eventually be putting a case on it that covers the buttons most likely. however if this isn't normal behaviour I would at least consider swapping it for another model.
My phone has a slight rattle when shaken but I'm sure this is the camera stabilisation module - my 920 has it too, but there's much more of a rattle on the 920.
niedrie
