Solution to battery drain
jay minhas
5
Not sure if this has been posted yet or not but I, like many others have been experiencing a severe battery drain on my 928. I tried stopping background apps, uninstalling some apps, rebooting phone but nothing seemed to work. I started messing around with all of my settings and I noticed that my email, in this case Gmail, always took forever to sync (at least 5-10 minutes) ... I have no idea why it takes this long but I switched the sync option for all my email to "manual" so its not spending all day syncing emails in the background. I have noticed a substantial change in my battery life.
Hope this helps
ttsoldier
Retired Ambassador
Dec 4, 2012
4,351
Hope this helps
Thanks for the tip
donebrasko
279
I may try that. I have 5 email accounts going. I have work, Gmail, yahoo, yahoo, and outlook. Maybe its time to consolidate. I would really hate to have to manually update. What uses more battery, push email (outlook) or the way Gmail and yahoo is syncing every so often?
Joel S79
148
Push email uses the least amount of battery since it doesn't react until it's told there's an email. That said, I was under the impression Gmail uses a push protocol.
jay minhas
5
Not sure how it works but for myself atleast, Gmail takes about 10-15 minutes to sync. And since I had Gmail set to automatically sync every 15 minutes, it pretty much kept going all the time in the background. Anyways, I hope this helps out at least some people!
Fred Simpson
Banned
Aug 7, 2013
7
On my 928 any navigation or game app I've used will drain my battery 11 to 12% inside first 20 minutes with all background tasks off . Phone uses power great otherwise but not with apps.My concern is batteries don't get better with time and Lumia's is non removable I think
Joel S79
148
The AMOLED screen can really dig into battery life, so expect things that keep the majority of screen on for a long time to drain battery quickly. I turn the screen off when navigating and usually just rely on voice unless the intersection looks crazy. It's also good to keep the black background theme, black means off pixels for AMOLED, so you'll save some battery life there.
Riverrunner88
55
You can set up your gmail account as an exchange server to push. Lot's of instructions on the web on how to do it.
I went 10 days and saw about a 1%/hr battery drain. I was going two days on a charge. 3 days go I'm back to 3to4%/hr and nothing has changed other than my "Battery" app was updated. The update shouldn't matter but who knows. Strange phone...
anon(7901790)
2,108
Gmail uses push protocol if you are on an Android phone or tablet. However, if you are using iOS, WP7/8, Windows, or Mac OS then it uses IMAP/POP3.
deadwrong03
1,028
u think the battery app could be causing the drain?
Funky Cricket
652
I do a soft reset after every major round of app updates. otherwise my batter starts draining. I think it has to do with how the apps try to check into location services. Otherwise I don't have too many issues with the battery. There are a few games that will eat it like no tomorrow though. fairway solitaire and NOVA are both pretty big energy eaters.
Beast of Haeven
447
I was getting anywhere from 10% an hour to 20% an hour after having everything set to always on and always updating. After cleaning things up I would get 9%+ drain an hour. After setting my yahoo account to manual sync and deleting unused apps I'm at 1.33% drain...wow.
Riverrunner88
55
I think it's the "battery" app. I don't think it's working properly and I may need to look for a different one. I'll do a soft reset and then I will get and bunch of battery life back so that leads me to believe I'm getting erronous info...
Example - This morning I unplugged at 0530 and by 0600 I was already at 70%. WTF??? Just did a soft reset and it now says 93%.
DavidinCT
Feb 18, 2011
3,310
I guess I do ok, My day starts around 6:30am, I browse Weave for at least 20 min every morning (and this included 2 short videos), about 40 texts, 10 times checking email, 2 phone calls (under 2 min each), Push on exchange and hotmail scheduled to sync ever 30 min. It's 2pm here, my phone is still at 86% left... I AM on LTE at home and work with a strong signal.
I do make sure there is only 2-3 apps running in the background...I normally kill everything as soon as I install them...
BrianDeeert
