Surface pro 4 wireless issues
Blairpoll
19
getting a bit annoyed I'm finding more and more issues with this device.
Found that for some reason it doesn't like connecting to my mobile hotspot surface pro 2 sat right next to it connects just fine and to shut down a restart the pro 4 several time to just get it to connect and then it seemed to work fine on both devices around 20mb/s download then I plugged a usb stick into the pro 4 and speed dropped right off to about 1mb/s down pro 2 on the same network was getting 20mb/s download sill. unplugged the usb stick and speed went back up WTF
Even i just purchased the pro 4...u need to check for updates...that fixes lot of bugs if u having them....
I had wifi issue after update its working great
RS-Driver
