surface Pro vs Surface Pro 2
jdom
135
is the Surface Pro 2 a big upgrade over the Surface Pro ?
I can get an refurb Surface Pro 128GB for $599
what do you think?
IMO, the Pro 2 is great if you're doing video editing, playing games or photoshop.
If not, then the Pro is fine, especially at that price.
However, battery life on the Pro 2 greatly eclipses the Pro.
That is very correct. Depending on what I'm doing, my SP1 battery doesn't last much longer than 2hrs. I may be able to double that if only doing light surfing and typing docs.
I dont know, i have a SP2 and if i was forced to only use single available kick stand option id get annoyed. i use the second kick (added to SP2) 95% of the time.
Better Battery life, better screen (same resolution, but improved, according to Microsoft), better speakers, better processor and graphics, and a better kickstand (2 position).
Depends on your use case. The main I held out for the SP2 was for the battery life. If you get a warranty on the refurb model that's not a bad deal SP1. For casual stuff I doubt the increased performance of the SP2 is noticeable.
roro8987
