Volume and Notifcations Settings Keep Resetting
steiny
Having a strange problem that just started in the last week or so that I can't figure out how to fix. For some reason, the volume keeps resetting itself on the right "phone" icon volume scroll bar to the bottom, or no volume. No matter how many times I bring it back up to full volume a few minutes later it's back to no volume without touching anything. The left "pda" icon scroll bar is fine at full volume always, it's just the right scroll bar.
The other part of this issue is that if I perform a soft reset or just use my phone normally, my notification settings also reset to no notifications at all, everything is unchecked! Is this a registry problem? Thanks.
Are you using any profile manager like SPB Phone Suite? If you are, simply select a different profile to enable the volume and notifications or edit one of the profiles to the settings you want.
Michael Niehaus
