What parts do I replace for dead pixels on my Nokia 920 screen?
mojacho
Nokia 920 Screen
Dear All,
i would like to seek your kind assistant & help. My nokia Lumia just fall off & No Crack on the screen. only dead pixels on the screen.
question : what parts should i purchase to replace this screen?
your kind help & suggestion is much appreciated.
Regards,
Re: Nokia 920 Screen
Buy a new phone. These things are not worth the repair costs
can someone let me know the part name for this? i am thinking to buy this parts. thank in advanced.
Take it apart, check the connections. It's possible something is still partly connected but loose. If that doesn't fix it, you likely need a new screen. Because you don't repair phones for a living and don't have all the expensive equipment for separating and joining these parts, you need the entire glass/screen/lcd/frame assembly. For the 920, I've seen those at around $30 on ebay. Example: Front Full LCD Display Touch Screen Glass Digitizer Frame for Nokia Lumia 920 | eBay (just an example not an endorsement or recommendation of the seller)
niedrie
