Why do I have a sudden battery drain on my Lumia 1520?
Sandipan Mallick
Sudden Battery Drain out problem with L1520
I have a Lumia 1520. Whenever I am using the phone with Data connection being on the phone with say Battery around 90% the phone randomly switches off and then when it restarts it shows battery at 2-5% level. I put it on charge and with 30-40 min i gets fully charged. I have closed all background app and use one single app and still having the problem. It it Win 10 OS.
Can some one help.
Re: Sudden Battery Drain out problem with L1520
Can some one help.
Are you using Redstone? Check Insider forum.
According to your battery behaviour, seems more a battery calibration error than other. A user told about two days of full charge and full discarge till phone came back to common charge times (30 mins are not realistic!!"
I have the same problem, but not caused by mobile data. For me it happens when i set max brightness (which I like to use). Whenever I set brightness to high, the phone starts acting crazy (the behaviou explained in OPs post). So now I'm on medium, but it's still not 100% right. I'm also using a 1520, it may be something device specific.
Nated2
