Will Flashing my Lumia 535 dual sim fix double tap to wake issue ?
lamblumo
135
I have latest march update but double tap to wake don work well.. sometimes i get ghost touch can flashing device fix the issue ?
What do you mean with gost touch.
Does your phone wake up without that you want it?
Or if you double tap the phone does not wake up?
By Ghost touch he means touches that are registered when nothing obvious is touching the scree.
Flashing device might help, but I wouldn't think so.
Ghost touch i mean is.. pressing backspace results in auto pressing of V instead of backspace.. pressing space actually presses K instead of backspace... and double tap to wake does not recognized by the cell... i have to tap many times to get it work...
Do you use a screen protector ?
If so could you try it without this protector.
Or if you clean your screen will this help?
Throw your phone!!! And get another lumia!! This is hardware problem.. There are a lot of another cheapest lumia which better in quality than stupid 535
Marchwind1949
