Window 10 build 10240 using microsoft basic display adapter rather than my graphics card installed
I have the identical issue, could you provide the link which driver could be adopted on win 10 64 bit? thanks a lot.
I have the same issue with AMD Radeon HD 4650 :( My screen is streched with whatever resolution i choose.
My screen has a 1920 x 1080 resolution and the best I can choose is 1600 x 1050.
Is there a way of getting some software to get back to 1920 x1050?
just go to windows device manager then update your display adapter, i also have an AMD graphics. The microsoft basic display addapter was the first adapter after i upgrade to windows 10, after i update the software driver it was now AMD.:smile:
I upgraded to Windows 10 from 8.1 and when I try to use Xsplit, it tells me that I do not have Direct3D Accelerator enabled. When I run dxdiag, it shows that it IS enabled. can anyone help me out? I have a "Generic Non-PnP Monitor" and my card is a "Inel HD Graphics Family card on a Lenovo ideapad S510p Touch laptop.
I find no list of Minitors
I also am having a problem with the Microsoft Basic driver, 'it don't work right!'
how do we eliminate it, ??
Using Build 10576 ..AMD|ATI on board graphics.
Sdiolutola
