Is there a way to Beam SkyGo with Surface Pro 3 and Samsung Smart TV?
WPCentral Question
Beaming SkyGo with Surface Pro 3 and Samsung Smart TV
Hi,
I have a surface pro 3 and a samsung smart tv which is around 3 years old. Is there a way of beaming skygo football to the tv wirelessly ? Will I need an adaptor and/or something like Netgear Push2TV ?
Thanks,
Anzzzz
Re: Beaming SkyGo with Surface Pro 3 and Samsung Smart TV
If you can go to a website and stream media content using with play to, you should be able to. To see if you can use play to, while having media content streaming from metro IE, swipe from right to bring up charms, choose, devices, then play, then choose your TV if it shows up. You can also do this to an xbox 360 if you have one of those.
lerato Mokoena
