Hi,
I wondered if anyone had this issue with there SP2.
I charge the device fully, use if for a little bit, check the battery and it's at 90%, that's all fine I think so I click the power button and close the lid. When I open it a couple of hours later it's at 70%. It's like the idle is not working.
The device is set to go to sleep automatically after 5 minutes but it doesn't seem to be.
Any ideas as to what the cause may be?
Thanks,
Nic
Thanks,
Nic
