Problem With Audio out/Microfone in surface rt
ManVSKing
3
Hi,
I am currently using windows 8.1 preview on my surface rt.Iam experiencing audio out problem.Whenever i connect my headphones it doesnt recognize.Ya headfones work perfectly.This problem happened suddenly on 4th of oct. I didnt make a recovery usb.So i cant factory reset or refresh.I tried by deleting the driver and refreshing.No luck.ANd i even entered audio playback in the search box and tapped fix and find audio playback problems.It says the speaker headset or hheadphone is unplugged.what should i do?Should i wait until oct 18.Any help would be appreciated.
Thanks
I am sorry to tell you this, but I think you just have to wait... :unhappy:
Hi,
Just want to know if you find how to fix this issue, I'm in the sam situation with my Surface RT, suddenly it doesn't recognize any headphones.
Kind Regards,
abcdzoony
