Is anyone else not have an issue with the battery indicator not updating? My indicator
is not updating properly. It still shows 100% when I know it should be less then that. If I leave it unplugged
all night and have a sound app running the whole night it should be down to about 70%. If I go to the desktop
and tap the battery icon it says 100%. Then If I do a reset as suggested in a different thread it will show the correct
battery charge.
I'm just wondering if it is my surface or are others having this issue?
Thanks
Dave
battery charge.
Thanks
Dave
