boltman2013
Banned
Re: Hesitating between Surface Book and Surface Pro 4
Truthfully look at the Vaio Z Canvas over both SB and SP4 its near that $2K..I think its the best choice based on what you described
VAIO Z Canvas
Windows 10 Pro
Microsoft Signature Edition
Intel? Core™ i7 processor and Intel? Iris™ Pro Graphics 5200
2nd generation PCIe SSD with PCIe Gen.3 compatibility (up to 1TB) or SATA/M.2 for 256GB model
Up to 16GB of memory
IEEE802.11a/b/g/n/ac
12.3 inch LCD WQXGA+ 2560 x 1704 IPS display
Keyboard, Digitizer stylus (pen)
Touch Screen
$2,199
Wide gamut display
The wide gamut display of the VAIO Z Canvas has 95% coverage of the Adobe RGB spectrum, and matches the standard LCD monitor used by professionals when they check color. Now your work flow can extend beyond the office to client and site visits. The true, accurate color means you can optimize tasks and apply a precise finish to your work.
VAIO Z Canvas Pen
Color management compatible
The VAIO Z Canvas lets you calibrate and match colors on a single device. And since color profiles of graphic cards can be rewritten on the VAIO Z Canvas, color management is stress free with no interruption to your work flow.
VAIO Z Canvas Battery
Battery life that outlasts you
Other devices that use the powerful processor are heavy consumers of battery life that require a nearby power source and limit where you can be creative. Although it is a compact body, the VAIO Z Canvas is equipped with a 63Wh high capacity battery. This means you can start and finish your project wherever the inspiration strikes.
VAIO Z Canvas
Windows 10 Pro
Touch Screen
$2,199
Wide gamut display
VAIO Z Canvas Pen
