1020 wifi connection problems
tweedie
221
nah, had zero problems connecting to wifi. both open network as well as secure (wpa2+psk)
I guess double check password? what wifi protection are you using?
odehhasan
5
I had this problem with my work WiFi internet. Keeps telling me incorrect password. Solved it by entering the router's home page and changing the security setting from wep to wpa2+psk.
Sent from my Nokia Lumia 1020 using Tapatalk
Dennis Hong
Hello there,
Go to your Wireless Setting > Manually > WPA > Cipher Type > AES
Use only AES
Do not set as TKIP
Works for me.
Cheers.
nita bhattarai
Hello!
I have updated my Nokia 1020 with Windows 10 but the WiFi doesn't work.
The WiFi button doesn't work, i mean, it is always stay on 'OFF mode'.
How can i turn this button on?
Thanks!
Carnes
