Windows Central Question
Problem with my lumia 930 brightness settings
After one of the last updates,i don't remember the build exactly but it was the one that the screen went black when updating I decided to reset my phone,I did that and the phone worked normally but now i can't change the brightness,i set it to low,medium,high or automatic but it stays very bright on all the options,i tried soft reseting and hard reseting but nothing worked,today i tried downloading windows device recovery tool to see if that will be fixed but everytime i try to use it i always get an error trying to install the packages.Is there a solution to this or will my phone stay very bright all the time,its hard to use the phone at night because of it and the battery last way less than it did before
