Hii All
Pls I need your help...
I also had the problem with my Lumia 920 , that the power button wasnt responsive ....
if I have switched the device off - If I have wanted to get it back on - most of the times when I have pressed the power on button
it didnt turn the device on , only when I did soft reset the device turned back on ....
My battery went went to 0 precent and I didnt have the time to connect the device to charger
so the device turned itself off..
Now I cant turn the device on any more
the power buton is not responding ...... soft reset, hard reset does nothing because I dont have battery power
of connecting the device to a charger or to the computer via the usb cable also dont do anything to the device ,
my device is dead only because i dint have the time to connect him to a charger in time ??
what can I do ?
Pls help
:unhappy:
what can I do ?
Pls help
:unhappy:
