My Lumia 920 with 8.1 Doesnt wake up anymore - Power issue . The phone is not charging
smarty99
Hii All
Pls I need your help...
I also had the problem with my Lumia 920 , that the power button wasnt responsive ....
if I have switched the device off - If I have wanted to get it back on - most of the times when I have pressed the power on button
it didnt turn the device on , only when I did soft reset the device turned back on ....
My battery went went to 0 precent and I didnt have the time to connect the device to charger
so the device turned itself off..
Now I cant turn the device on any more
the power buton is not responding ...... soft reset, hard reset does nothing because I dont have battery power
of connecting the device to a charger or to the computer via the usb cable also dont do anything to the device ,
my device is dead only because i dint have the time to connect him to a charger in time ??
what can I do ?
Pls help
:unhappy:
While plugged in press the volume down button and the power button at the same time.
If the battery charge is zero, it needs some time plugged to the charger to wake up, it needs some percent of charge.
Sent from my RM-820_lta_lta1_272 using Tapatalk
Also make sure it is plugged into the original AC wall charger, not some random USB port.
The power button can't wake up phone is a known issue for most Lumia phones. The work around that works for me so far is press and hold camera button to launch camera and it will wake up the phone. Also, remove Cortana live tile may help prevent it from happening again.
oh maaaaan!!!! god bless you!!!! **** it was really annoying in my mind. thanxxxxxxxxxxxxxxxxxx
longinotti101
