How to set MMS settings
Fred Wilson2
376
How do I set the MMS settings ?
I'm trying an AT&T prepaid card, which works ok other than MMS.
With another Windows phone that I have (Nokia Lumia 635), after the 8.1 update which happened as soon as I got that phone a month ago, there is a section to edit the MMS settings.
I don't see that with the ATVI under 8.0.
Thanks,
Fred
ShinraCorp
590
Thanks,
Fred
Is it on Windows 8.1? If it is you'll probably find it under Mobile+SIM settings then tap on SIM Settings/ Edit MMS APN and voila you're done :)
Carnes
