2500mAh battery for Lumia 820!
Hows the running time compared to the stock battery?
I find it to be around the same with the stock battery, lasts about a day with normal usage, at least it doesn't reach the heart by the time I get home (30% left). Usually the stock battery would've alerted me with the battery critical notification. Will do a battery drain test.
The MPJ does look dodgy as-well for me, I wouldn't risk any amount of coin to get it. the 820 has always been a battery headache and users are always desperate for a higher capacity battery that fits in the original case but I am afraid this looks like a hoax a higher capacity battery should be larger in size definitely.
What Battery Pro+ says about Mugen 1800mAh?
it has been established that battery pro cannot actually get that information from the battery. It's just displaying the number from the default battery your phone comes with.
Can someone search for an app or other techniques to gauge the power of this battery?
The charging time of larger battery should be longer with the same charger I think, you can try that
Now from the post above I realized something. I have a Traxxas E-Maxx that I havent driven for few years. But I naturally have very sophisticated charger for it for charging the LiPo's. I guess it might be possible to see the mAh from batteries with it. If I have time to mess with it at some point, I will dig the charger up and try to measure mAh's from these batteries if possible.
Kind of off topic can anyone recommend a Bluetooth keyboard case cover all in one yet keyboard comes off for dell venue pro 8
"Kind of off topic"...probably the understatement of the year!!! BTW, after a few more weeks of usage I still stand by my first post in this thread.
HAhaha, I came back to report only that my battery has finally arrived. However last posts made my day, got probably the best laughs of the week.
I will pick up the battery from post office tomorrow, but as it is NYE etc, expect feedback end of the week.
Hey am using this battery 2500mah .no use guys still the battery does not improve. It remains same as original.it is definitely placebo effect.due to battery life this phone is not gud for browsing.
Sent from my WPCentral Forums mobile app
Hey that's it.stock battery is better than the 2500Mpj battery!cool
Sent from my iris458Q using WPCentral Forums mobile app
what if it depends on the usage difference by different people. What do others say. Got one review like this..
niedrie
