Can anyone help me with a low storage problem even after a hard reset?
v535
491
can anyone help me with low storage problems even after hard reset
Hey everyone, after a hard reset I tried some games and apps and decided to uninstall some apps. After uninstalling some apps, I must regain some space but some data is leftover thereby resulting in partial uninstallation of apps. Currently only 1GB is free, mind you I did a hard reset just couple of months back. What should I do, will w10m solve these issues? Will moving the apps to sd card result in battery drain?
AFAIK, frequent hard resets will eventually increase wear/tear on eMMC, now what should i do?
Re: can anyone help me with low storage problems even after hard reset
Have you tried clearing temporary files or browser history? Even apps like WC end up taking cache memory.
There's an app called Storage Cleaner. Give it a try.
Tried everything in Wp8.1 playbook. Even I filled up the entire disk using storage cleaner app and instead of freeing up the space it increased by several 100 megs. The problem is, i play a game until completion and then I uninstall it. In wp8.1 I must keep the unused apps on phone memory to prevent ever increasing other storage. Looks like, a reset can fix it, will try once stable w10m is rolled out.
joseeduardo
