Can I get some help with an APN settings problem on my Lumia 1520?
sinatv52
4
APN setting problem Lumia 1520
hi, how can i edit APN settings on my lumia 1520?
the Operator rapidly sends me sms that my settings are not correct and makes my internet speed so slow,
as you know there is no apn settings in wp8.1 and Access Point does not work in wp8.1. :straight:
You would have to go to Settings > cellular + SIM > SIM settings > Manual Internet APN must be toggled to "On" > edit internet APN
I don't know what APN to advise you to input as I don't know your country and carrier. I see MTN on your Passport Profile, but not what country. The APN for MTN will vary from country to country...
My phone got updated 10.0.12562.84 and now i'm unable to send/get picture messages and unable to use data.
Nokia 1520 unlock on Tmobile
When I go to add Internet APN the only options I have are:
APN
User Name
Password
Proxy Server (URL)
Proxy Port
Any help will be great thanks WP
APN
User Name
Password
Proxy Server (URL)
Proxy Port
Is it unlocked from ATT? Did you try a reboot since the update? That should get the settings right from the SIM. My Factory Unlocked 1520 never had a problem on T-Mo. It always configured itself.
Try these settings (click the Windows mobile 8 link): Mobile Phone Carrier Settings for T-Mobile - United States
You may want to also try all those above linked but substitute "fast.t-mobile.com" (no quotes) in place of APN for internet and MMS.
Michael Niehaus
