Can you help with Lumia 1520 charging problem?
WPCentral Question
Hi all,
The past few days my 1520 has taken a super long time to charge and last night I put it on the charger at 63% and woke up and it was at 42%. Battery saver shows 16% usage when plugged in but as soon as I unplug it drops to -2.5% so basically when I plug it in the drain on the battery is slightly faster than the charger. Anyone have any ideas?
Thanks in advance!
Kevin
DamjanPetkovic
8
Hi Kevin
What type of charger do you use?
Try to charge with another charger.
If your charger is ok, then you should try soft reset of your phone (Volume down+power button until device vibrate).
If your problem persists, do a factory reset, then do 3-4 charging cycles from 10% to 100%.
I hope this may help you.
bvncgvgnvb
