Got problem with mobile power
conantv1989
4
I have a mobile power from Pisen ( Easy Power IV Power Bank 10000mAh ). I often use it to charge for lumia 520, galaxy note 3 and Iphone 4S. But it didn't work for lumia 950 XL. I dont know why. Cause 950 XL use USB-C so I used the cable included when I buy the phone to connect between 950 XL and the mobile power. Does anyone get the same problem like me and how you solve this problem? Or you have any idea about this?
Thank you so much!
Thank you so much!
when you say it doesn't work, do you mean it doesn't charge at all or that the charging is slow?
Thank for your care. I mean it doesn't chagre. Does the mobile power not have enough power to supply to the phone?
Really? I already tried the cable included when I buy the phone but it didn't charge. Here's my mobile power Easy Power IV Power Bank 10000mAh , please help me reference the link and is there any problem with the mobile power. Thank you so much!
I had this solar charger for years, can't remember where I bought it, you should be able to buy something similar that works. Do note that the charging speed is not very fast.
ikemefuna1
