Hey all
My 950 xl UK wall charger has gone on the blink, not sure why because it just stays in 1 socket permanently, why MS had to mold the cable into the charger.. I dont understand, a USB socket wouldve been better ... but there you go..
Im wanting to replace it.. Ive found an official MS one by a UK seller.on ebay for ?15 free p&p, but would any 5V / 3A charger be ok, or should I get the official MS one?.
Also, at the moment Im using my G4 charger which is 5V / 1.8A along with a USB C cable into the LG charger... it seems to be charging ok, and I figured with the LG charger being a lower Amps (1.8A), but same voltage (5V) it will be be a slower charge but safe enough to use for now.. Is that right?.
Thanks for the help
Thanks for the help
