Here Drive and audio through handsfree bluetooth connection
Carlos M Duarte
9
Hi,
I apologise in advance if this is the wrong forum but I couldn't really decide if this was an app or OS "problem".
Does anyone know of a way to get Here Drive to give directions through the speaker instead of the bluetooth handsfree connection? It's really annoying to have it stopping the radio to give directions, even more so when it's absolutely non-seamless (you get pauses before and after the directions, when the BT connection is being established). As is, the app is unusable for me. (And no, I cannot just disable BT because I need the handsfree for taking/making calls).
Thanks!
It's a limitation of the OS. It doesn't currently allow for multiple BT connections as far as I know. Not sure if future OS updates and newer hardware will change this.
Sure, I get that. What I would like to know is if there is a way for Here NOT to send audio via BT. I only get this with Here, not with Waze or CoPilot.
longinotti101
