Hot and reduce battery life faster
yoongwaikhit
8
When I playing game or using internet explorer, it feel hot , then I stop playing and stop using phone, standby mode, it continue feeling hot and reduce battery life.
I've discovered that I had a ton of APIs running in the background that I don't really need to be running. May be worth looking in Settings/Battery Saver (if you're on 8.1).
It's easier to block background tasks in W8.0 compared to W8.1 - just hit the "blocked" button. Now, you need to click and it will bring you to another panel where you need to slide it off.
Put your phone in freezer. I did it once. No kidding :)))
They aren't air tight. I'd worry about condensation inside as they warm back up later. Could have corrosion problems at connections down the line.
johnaw
